Prelude CPR install question
Posted: Wed Sep 20, 2017 10:41 pm
Hi,
I've recently purchased and installed the hondata cpr kit.
The vehicle is a 1999 prelude with the S300 in a OBD1 p28. Distributor installed right now is a OBD1 with an external coil.
I followed the installation instructions exactly. The problem I found is that the 4pin connector on the external coil needs to be plugged in for the engine to start. With it disconnected, the engine will not start.
Any particular reason for that? The red and green wire is wired to the 2-pin plug off the distributor.
