D16y8 turbo
bigspenc93
D16y8 turbo
Post by bigspenc93 »
Hi, I recently turbo'd my d16y8, and am using a p28 with s300, and a jumper harness. I'm running a y7 turbo base map.
So my problem is, while going down the road, boost will hit, and the clutch will slip, then check engine light will come on and put car into a limp mode. Error code will not come up on smanager.
Any ideas?
Anyone have a d16y8 turbo map?
Re: D16y8 turbo
Have you datalogged this happening?
HAs this been properly tuned on the dyno?
bigspenc93
Re: D16y8 turbo
I have not had it dyno'd yet. Also have not data logged it. Will look up how to data log, then I'll try to post it on here
bigspenc93
d16y8 turbo
does anyone have a d16y8 turbo map?
dont have money to dyno tune right now, and want to be able to safely drive it to work and safely boost it.
im running a cx racing turbo kit, ramhorn manifold, 8 psi wastegate, rc550 injectors with 10 ohm resistors wired in, with a p28 ecu.
thank you
coryfrerichs82
Re: D16y8 turbo
Post by coryfrerichs82 »
I am also in dire need of a good base map for a boosted d16y8 if anyone has one!
