Speed Adjustment
Speed Adjustment
Can we have these tables put in for the RDX please.  Anyone that deviates from factory tire size would benefit from this. Transmission gearing isn't really an option for this car so tire diameter is the easy route, since the FWD models come with a taller final drive then the AWD versions.(4.312 vs 4.533)
						Re: Speed Adjustment
If not gearing than how about a speedometer correction capability?94b20gsr wrote: Sun Sep 10, 2017 7:24 pm Can we have these tables put in for the RDX please. Anyone that deviates from factory tire size would benefit from this. Transmission gearing isn't really an option for this car so tire diameter is the easy route, since the FWD models come with a taller final drive then the AWD versions.(4.312 vs 4.533)
Been a few months with no update.  Please advise.  My current tires are a little different than oem so the speedo is off now.  I'm also toying with the idea of swapping in an AWD transmission into my FWD for the gearing.  Leaving it FWD, not trying to implement the other components.
