Page 1 of 3
No Signal Output from Traction Controll Unit
Posted: Sun Sep 03, 2017 11:41 pm
by Renko
It was well working.
I wasn't runing the car for a while. The traction controll isn't working anymore.
I did some Software update on the the kpro.
There is just ELD 0.27 Volt reading on the kpro. Which Output must come from the TC Unit?
Tanks for your help
Re: No Signal Output from Traction Controll Unit
Posted: Tue Sep 05, 2017 9:05 am
Plug in both the TC and KPro to a laptop, and test the TC output (Traction Control window, Testing tab, Test output to ECU). In KManager datalog and check the input (ELD or S02) shows the same voltage. If that does not work, it is wiring. If that does work, then it is configuration or wheel speed sensors.
Posted: Tue Sep 05, 2017 1:24 pm
by Renko
The input ECU / ELD is the same voltage as I elected in Testing tab.
The signals are coming from al wheel speed sensors.
I did not change the configuration. Should I send you the conrfiguration to consider it?
Posted: Tue Sep 05, 2017 1:48 pm
post the calibration, traction control calibration file, and datalog made with both USBs plugged in.
Posted: Wed Sep 06, 2017 1:07 pm
by Renko
How can I get the datalog. It looks like empty space. There no content. Consider the attachement
Posted: Wed Sep 06, 2017 1:18 pm
You must datalog using KManager on the laptop.
Posted: Mon Sep 11, 2017 12:55 pm
by Renko
Here some datalogs and calibration
Posted: Mon Sep 11, 2017 3:36 pm
you need to also post the calibration you have uploaded to the K-Pro that these datalogs were made with.
Posted: Tue Sep 12, 2017 11:40 am
by Renko
Calibration from KPro or Traction Control? I send you both.
Posted: Tue Sep 12, 2017 12:57 pm
You have no wheel speed inputs. Try calibrating them in the traction control window. Also check all your wiring as it looks like something has changed since it was previously working.
Posted: Thu Sep 14, 2017 4:04 am
by Renko
That's strange. I do have the Wheel Speed Input in Software / Windo: Error - Error Counters - In the Pulse Count left front, right front etc. . Even on the TC Unit LED are showing the Input from each wheel.
Posted: Thu Sep 14, 2017 9:33 am
Then you did not create the datalog with both USB cables plugged in. Do that and repost the calibrations and datalogs.
Posted: Thu Sep 14, 2017 1:58 pm
by Renko
I can not datalog during driving. It is a pure race car with one seat and not driveable(legal roules) on the legal street. In this case I have to drive on race track with laptop? That is not realy a solution to track datas.
Check the following url: https://www.youtube.com/watch?v=m_-_JG0O4bY
Posted: Mon Sep 18, 2017 11:59 am
Just drive it around the pit or paddock. You don't need to be at full speed.
Posted: Sun Oct 01, 2017 2:16 am
by Renko
Please check the data. The signal from the RR Sensor is in miles, instead of km/h like the other sensor. That's strange.
2_Romont_Test_TC2.kdl
