Graph on stock use+equivalent map
Posted: Fri Sep 01, 2017 8:33 am
Hello,
If the graph recognice knocks in use of the stock map?
Knock control goes up. In some terms the knock retard goes to 9-11°, but no knocks detected.
I see the 2.8.2.0 sofware are compared with more tables.
I want to use the stock equivalent map with the radiator fan control. Is it save to use without customize? Because Hondata says, it close to stock as possible.
Thanks for you answer.
