How can I get column 10 activated on fuel table
Posted: Thu Aug 31, 2017 10:05 pm
by bian.yy
Hi Hondata
How can I get my column 10 of delta fuel table activated during road tuning WOT. I am already push down to floor, you can look on tplate data.
Setup is K24A2 + 421 header.
Re: How can I get column 10 activated on fuel table
Posted: Fri Sep 01, 2017 8:35 am
If the air pressure is not high enough or you have intake restriction then you will not reach column 10. This is normal.
Posted: Fri Sep 01, 2017 4:51 pm
by bian.yy
Hondata wrote: Fri Sep 01, 2017 8:35 am If the air pressure is not high enough or you have intake restriction then you will not reach column 10. This is normal.
Ok, I understand, because of my intake is still stock, do you have any experience if I change to CAI for higher flow will it obviously decrease low end torque from 1000 to 3000?
Posted: Sat Sep 02, 2017 3:10 am
by mladjan
When you "open" exhaust, engine will need more air, and stock intake is restriction. CAI may help (with good velocity), but also bigger throttle plate and ported intake manifold will help. Try first with CAI, its cheeper.
Posted: Sat Sep 02, 2017 3:23 am
by bixer
on NA engine , too large throttle plate will decrease the air flow velocity and this will further decrease low end torque by geopartizing the valve overlap in that area.
Posted: Sat Sep 02, 2017 8:15 am
If you live above about 1200 feet then you're not going to get to column 10 because of the air pressure, depending on the atmospheric conditions. It is normal.
Posted: Sun Sep 03, 2017 8:24 pm
by bian.yy
Yes, I am living 1345 ft. So I don't need to care about column 10 then.
