can somebody check my cal please
Doony74
Post by Doony74 »
hi new to all this and just uploaded a map to my ecu
I have milltek exhaust and hsk intake any feedback woukd be appreciated
Jun43
Re: can somebody check my cal please
Post by Jun43 »
it runs rich
Doony74
Post by Doony74 »
how can I change it ????
Doony74
Post by Doony74 »
added current calibration
Lerlo
Post by Lerlo »
It seems you are using MAP to determine WOT.
For me at even 40% the MAP is above 0.7 bar.
As such you are mostly driving in WOT.
Your Low WOT adjustment table, why did you richen it to 11.98? That's way too rich.
Your High WOT adjustment table, you leaned it to 12.98? That essentially keeps you at closed loop which is not right
Your High Ignition table is advanced significantly which explains your high knock numbers.
Your VTC table shouldnt look like a perfect rainbow to be honest.
I think you should scrap this cal as its not doing your car any good.
Use the group N as a starting point, do the AFM calibration and make small changes.
Give my cal a try if you want, its on the conservative side
