Smanager V2.5.5 flex fuel bug ?
b16itb
Post by b16itb »
Hello.
I started using the flex fuel option with the GM sensor on my S300 v3 using the Digital AN0. Sensor works great.
But I can´t change the Smanager to see more than E85. the option is locked. Here were I live we have E100 on fuel pumps, so I need to be able to ajust to 100% of ethanol.
How is possible to make the correction above E85 if 4.25v is E85 and 5v still E85?
I´m using latest smanager (v2.5.5 1/10/2017 )
Re: Smanager V2.5.5 flex fuel bug ?
That table is only used for an analog ethanol content input. If you are using a digital ethanol sensor, then the sensor outputs a PWM signal that is converted directly into ethanol %
b16itb
Post by b16itb »
Hondata wrote: Mon Jul 31, 2017 8:18 am That table is only used for an analog ethanol content input. If you are using a digital ethanol sensor, then the sensor outputs a PWM signal that is converted directly into ethanol %
Now I realize that was a dumb question.. it says "analog" on that table. Sorry.
Tomorrow I´m going full E100. Thanks a lot for your time answering all the questions.
