GSR Trouble Shooting
Posted: Thu Jul 20, 2017 3:20 pm
by JdmGsr17
Hello, i have a JDM GSR B18c with Type R cams. I started the car with my new s300 with a GSR Tune i found here and it ran for a bit then the timing went off. Does anyone know how to figure out what TDC Degree i have to set it as ? i know i have to advance it because i have to run 93 cause of the cams. Thanks
Re: GSR Trouble Shooting
Posted: Thu Jul 20, 2017 3:39 pm
by Jun43
GSR requires 91 or higher no matter what
what do you mean the timing went off?
Posted: Thu Jul 20, 2017 3:50 pm
by JdmGsr17
At one point after a start up, the car kept cranking but no startup. I was getting spark and Fuel. My buddy and i concluded that the timing was off again. now im trying to figure out which BTC to set it up to
Posted: Thu Jul 20, 2017 3:55 pm
by Jun43
JdmGsr17 wrote: Thu Jul 20, 2017 3:50 pm
you set it to 0 when the engine is off with the cams at TDC with no cam degree adjustment
when the engine is on - fully warmed up at normal idle speed. check it with the timing gun and set it to 16BTC
what calibration did you use? I don't think i saw any GSR with ITR cams map.
Put a stock GSR map on it and see if it starts up but don't drive on it
Posted: Thu Jul 20, 2017 4:48 pm
by JdmGsr17
i used this tune -
https://www.hondata.com/forum/viewtopic ... 293#p93293
and will do. going buy a timing light gun tomorrow
