autometer sensor alternatives
Posted: Wed Jul 19, 2017 5:29 am
by Thomas86
Hello Everyone
I'm Thomas and new to hondata as well as the forum.
Since a few months i have a Lotus Elise whit a Honda K20Z4 engine in the back connected to a Kpro4.
Because i drive trackdays i have purchased an AIM Solo DL and i would like to log engine oil pressure and temperature.
According to the following pdf i need an autometer 2246 and 2252 sensor connected to pins 15 and 16 of the Kpro4.
(page 8 of 9) http://www.aim-sportline.com/download/e ... 01_eng.pdf
However, it only seems possible to order these sensors in the US whit a shipping charge of 100 USD, which is a waste of money.
Can i use any alternative sensors in combination whit the Kpro4 ?
Best Regards,
Thomas
Re: autometer sensor alternatives
Posted: Wed Jul 19, 2017 9:24 am
Any inputs through the digital or analog inputs on the K-Pro can be seen only in the Hondata software and cannot be seen by any external sources. They will not be sent to the AIM.
Posted: Wed Jul 19, 2017 2:18 pm
by fonzeka
Ehh, that information is distributed on the CAN output or are you going to remove that?
https://www.hondata.com/help/kmanager/can_output.htm
To OP, pretty sure you should be able to use any sensor with the same measuring range.
Posted: Wed Jul 19, 2017 2:38 pm
I was not aware you were referring to CAN, I assumed you were referring to the info in our help file for the AIM output: http://www.hondata.com/help/kmanager/ai ... ub=digital
If it can use the CAN signal then it contains the supported channels listed at: http://www.hondata.com/help/kmanager/can_output.htm
The info you are listing about different pins is not supplied by Hondata. You will need to contact AIM for clarification about the sensors.
Posted: Wed Jul 19, 2017 3:04 pm
by Thomas86
So for a pressure it would be any sensor whit a 0 to +5V range correct?
https://www.hondata.com/help/kmanager/i ... essure.htm
As for a temperature sensor it can be any of those listed in the following link
or whit the same output characteristics. Any idea where i can get that data
in case the listed sensors are not available where i live? (doubt it)
https://www.hondata.com/help/kmanager/i ... rature.htm
Regards,
Thomas
Posted: Wed Jul 19, 2017 3:10 pm
AIM is the one saying you need a specific sensor for both. If you are unsure you need to contact them for clarification as it sounds like they have a specific sensor in mind for the protocol they are receiving.
Posted: Wed Jul 19, 2017 3:20 pm
by Thomas86
Ah right, Ill do that thank's.
But for the hondata itself it does not matter as long as the criteria in the help section i linked is met?
Posted: Wed Jul 19, 2017 3:26 pm
You can set up other sensors with custom values, but they probably will not work correctly with the AIM.
