Ignition Grounding Issue
Posted: Tue Jul 11, 2017 6:23 pm
Hello,
I have a k24a2 swapped mr2 spyder running kpro v4, and I have been having an issue with the ECU not grounding the EFI main relay. I have tested the coil side of the relay and I am getting 12v. I traced back the ground wire to make sure it went to the ecu and it is for sure connected to pin E7. The relay will not trigger when I turn the key.
I have tested the relay and It works great, I have also swapped relays to make sure that wasn't the problem.
Have you ever seen this issue with the ECU's?
I also have a p0563 VBU high voltage code, which I have read is because the main relay is wired incorrectly. Would this have any effect on the E7 pin not grounding?
Thanks guys!
Thanks guys!
