Hi,
I have a Kpro V4 ECU for aK20a2 and want use a PLX wideband lambda. Short question, is it possible?
KPro V4 PLX wideband lambda
Re: KPro V4 PLX wideband lambda
Yes. You can wire it into an analog input or digital input in the KPro4. You can run closed loop from the PLX or factory o2 sensor.
You mean one of the seven analog pins inside the ECU?
Yes. See:
http://www.hondata.com/help/kmanager/analog_inputs.htm
The digital input is more accurate but more difficult to wire up:
http://www.hondata.com/help/kmanager/digital_inputs.htm
