Quick question AF corrected
Posted: Tue Jun 27, 2017 6:47 am
by Admanirv123
Hi,
Do i still use the AF corrected value for tuning and data logs, is this the most accurate parameter to use?
2006 US.
Re: Quick question AF corrected
Posted: Tue Jun 27, 2017 9:26 am
That only applies to the Civic SI. You can double check it on the dyno by comparing the reading to the reading the dyno gets.
Posted: Fri Jun 30, 2017 7:52 am
by Admanirv123
Thank you
Posted: Mon May 07, 2018 3:01 pm
by CTRLFRK
Sorry to bump this thread but are you saying that S2000's should not use the AF corrected?
We should only use the AF?
Posted: Mon May 07, 2018 3:21 pm
That is correct.
Posted: Tue May 08, 2018 8:36 am
by CTRLFRK
Spunkster,
Do you have a recommendation for a Wideband 02 sensor that I can wire into the ECU that does NOT require me to purchase a gauge? I'm only interested in using the input in Flashpro Manager to verify my AFR's.
Posted: Tue May 08, 2018 10:36 am
PLX Devices offer a good selection of wideband controllers.
