Quick question AF corrected
Admanirv123
Post by Admanirv123 »
Hi,
Do i still use the AF corrected value for tuning and data logs, is this the most accurate parameter to use?
2006 US.
Re: Quick question AF corrected
That only applies to the Civic SI. You can double check it on the dyno by comparing the reading to the reading the dyno gets.
Admanirv123
Thank you
CTRLFRK
Post by CTRLFRK »
Sorry to bump this thread but are you saying that S2000's should not use the AF corrected?
We should only use the AF?
2006 Honda S2000
That is correct.
CTRLFRK
Post by CTRLFRK »
Spunkster,
Do you have a recommendation for a Wideband 02 sensor that I can wire into the ECU that does NOT require me to purchase a gauge? I'm only interested in using the input in Flashpro Manager to verify my AFR's.
2006 Honda S2000
PLX Devices offer a good selection of wideband controllers.
