No launch control
dvergara
No launch control
Post by dvergara »
A few days ago I did a tuning of a FA5 2009 k20z3 car with a very old map. When installing my map the launch control stopped working.
With the previous map it was not necessary to have the foot in the clutch
The car has no mechanical problems .. the cruise control works perfectly. Any idea of this problem?..
If I accelerate instead (1) with the foot in the clutch the rpm goes to court
dvergara
Launch Control stopped working
Post by dvergara »
Hello Hondata support
Can you help me with this
If I accelerate With clutch pressed the rpm goes to court 8,600 rpm
If I upload the old map the problem is solved .. the old map does not show progress bar or gas mix in rpm gauge
Re: No launch control
Post the calibration. Is it a Race calibration?
dvergara
Post by dvergara »
Is a car of daily use. With header, intake, etc.
Attached map
This map I am using it in other cars and do not have the problem with the launch
From Help, About, what is the version of software that you are using?
dvergara
Post by dvergara »
FP 32 bit
ver 2.7.3.0
Please download the newest version of software form the website and see if that resolves the issue you are having.
dvergara
Post by dvergara »
Install the latest version and update the map and the FP. The fault persists.
I attached a log
Launch control will only work when the vehicle is stationary and the clutch is depressed.
dvergara
Post by dvergara »
I know but it is not working
