2002 rsx base using stock rsx S map
esprout862007
Post by esprout862007 »
I have a 02 rsx base that has a prb kpro ecu. Although I have the k20a3, the only stock map that will work is for k20a2 and I'm assuming that is only because of the prb ecu. I attempted to use a k20a3 map and the car would not turn over. So my question is, with using the k20a2 stock map (which allows the car to run), do I need to make adjustments in the settings of the tables and parameter to match what the k20a3 stock map would be?
Re: 2002 rsx base using stock rsx S map
Did you disable the immobilizer before uploading to it? It should start and run the car.
esprout862007
No...I will try that in an hour when I get my laptop, and I'll let you know.
esprout862007
That still didn't work. Doesn't want to turn over
Does the engine not turn over (crank) or not start? There is a difference.
esprout862007
Sorry, it's cranking over, trying to start. But that's it. It seems to only work with a k20a2 map
From Help, About, what version of software are you using?
esprout862007
Version 4.3.3.0
I have tested the PND calibrations and they start the car as they should. I suspect there is some other cause to the car not starting.
Can you post the calibration you are using that does not work.
esprout862007
Will do once I get home. I will attach the stock calibrations that is in my kpro that I have tried for k20a3.
esprout862007
I will also attach the calibration that does work.
esprout862007
these are the two calibrations. The one that is working and the one that is not. Its a k20a3 engine with X2M5 6 speed transmission with PRB Kpro ECU. Also I do have some bolt-ons, RBC header, Ktuned 3.5" CAI with velocity stacker, straight 2.5" magnaflow exhaust with cat, 70mm rsx type s throttlebody, skunk2 apha serie headers, aem fuel rail....I think thats it. I need to install my new o2 sensors as the ones installed are reading flat and making my A/F ratio very rich. But anyways, this is what Im working with...I will be gone for about 2 weeks....going to China...so no rush, and I appreciate any and all help. Thank you
esprout862007
I'm back from China...did you have a chance to look at my calibrations?
I cannot see any thing that stands out that would keep one calibration from starting. Have you tried disabling lean protection?
esprout862007
No, at first I just tried with stock calibration of k20a3, then I tried with changing that multiplexer option. If that lean protection is checked in the box I will uncheck it and try again
