Pressure sensor ground. LOGIC or SENSOR?
Posted: Mon Jun 12, 2017 1:49 pm
by TurboTommy
1.In the the Smanager instructions for adding additional pressure sensors, it says to use logic ground, I wanted to make sure this is correct as I thought logic ground is used to ground shielded cables and sensor ground is used for sensors.
2.Can I use the ground on the s300 Analog section and use 5v ref from a tps ? Thanks
Re: Pressure sensor ground. LOGIC or SENSOR?
Posted: Mon Jun 12, 2017 2:15 pm
You must use the ECU logic grounds
"Be careful! The logic ground pins A26 & B2 are next to +12V pins, which will damage the S300 / sensor if connected by mistake."
No you should not use the grounds on the s300.
Posted: Mon Jun 12, 2017 2:50 pm
by TurboTommy
Thanks! But is there any particular reason why its logic and not sensor ground? Just trying to understand, thanks!
Posted: Mon Jun 12, 2017 3:12 pm
Logic ground is a volt ground.
