Car when i bought it i was told had this list of parts plus possible some more i dont know about.
b18 block sleeved to 84mm with arias pistons, and oringed by golden eagle.
eagle crank
gsr head
scat rods
arp main and head studs
type r cams
ls trans
precision 5858
sheepy built mani
bwr rad
moroso oil pan
msd ignition
blox intake mani
1000cc injectors
clutch
lsd
head gasket
s300
tial wg and bov
electric boost controller the hondata one
hondata map sensor
most of this i can confirm is true i am taking pan off soon to check inside the motor alittle. I was told it was on 18 psi when i got it but the car didnt have a boost gauge and it made alittle over 400 whp on pump 93. so i put a boost gague in it when i got home and its looking like its around 9 psi in first and 9 in 2nd and 3rd and up is around 11-12. So my questions are cause i had a firend peak at the tune tonight and hes in same boat as me not to up on the honda tuning yet. but he was saying it looks like the electrionic boost controller isnt even being used is this true ? am i currently running wastgate only ? it all looks hooked up to me. can anyone tell me anything about this tune ? possible boost numbers ? im pretty sure these are the correct files to post.
