No Lambda reading / code P0134
Posted: Wed May 17, 2017 12:26 am
by Renko
No lambda reading / code P0134
In beginning everything was working well for a long time (1.5 Years).
Suddenly from time to time the code P0134 comes up only when the motor was running in idle. I have checked all the wire and relays. Even the Lambda voltage values are ok.
After a while the ECU starts to take more and more time with starting reading de the lambda value.
I replaced the wide Band OEM Lambda 36531-PRB-A01. Same thing.
New setup dyno tuning by a professional tuner and official Hondata Dealer Chip Racing in Switzerland.
After the very successful hill racing weekend the ECU isn’t any more reading the lambda value. Starting engine 14.7, then it stays by 10.7. Do know this kind of problem? Can it be the ECU?
Extreme Hill Race Car EG6 with fully made Motor K24 / K20 Head. Kinsler individual throttle. 360 horsepower.
K-Pro 3 / 4.3.2.0
ECU: 37820-PRB-305 / 2054-100965 0G18
Let me know if you need more information’s?
Thanks for supporting me.
Re: No Lambda reading / code P0134
Posted: Wed May 17, 2017 10:53 am
Have you tried the ECU in a known working vehicle?
Posted: Wed May 17, 2017 11:03 am
by Renko
No, that will be very difficult to find a car.
Posted: Wed May 17, 2017 11:18 am
I would suggest you try that as that will help you narrow down very easily if it is ECU related or something in the vehicle.
Posted: Wed May 17, 2017 11:30 am
by Renko
Would that way the most easy solution be?
Posted: Wed May 17, 2017 12:28 pm
by Renko
Ok, I’ll tray to find a car.....but this is the ECU for an Acura RSX. We do not have such cars in Switzerland. Should it also work with EP3 Euro Version PRA? I don’t think so.
Posted: Wed May 17, 2017 12:44 pm
It will work, but you cannot test the o2 function on an EP3 as they do not have a wideband.
Posted: Wed May 17, 2017 12:50 pm
by Renko
To chcck the signal or to get any lambda reading is it necesary to work with wide band?
Posted: Wed May 17, 2017 1:10 pm
that is correct.
Posted: Thu May 18, 2017 1:14 am
by Renko
To find a right car to test the ECU is almost impossible. Do you have the possibility to test the ECU? If yes, we could go this way and do the update to K-Pro 4. How long do I have to estimate to send the ECU in your house and send it back to Switzerland. How much does it cost.
Posted: Thu May 18, 2017 4:32 pm
You could test this in a DC5 Type R to see if it reads correctly. They use the same sensors.
The cost of shipping back and forth will probably make this a very expensive test.
Posted: Fri May 19, 2017 3:51 am
by Renko
We don't have DC5 in Switzerland. In this case I must have an other possibility to test the ECU
Posted: Fri May 19, 2017 11:43 am
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this post.
