Hondata app datalog question ( Wideband )
Posted: Sun May 14, 2017 9:35 am
by ocram_88
Hello guys!
I've just installed a S300 Hondata on my USDM P28. Everything seems working as it should. I uploaded B16 USDM base map and car runs fine. I also installed a PLX wideband and wirded into Analog inputs. SManager reads perfectly Wideband value and it's the same showing the gauge. Actually i'm looking for adding Wideband reading into Hondata app but i am not able to do that.I can read only O2 stock sensor in app. Hope you can help me. Thanks a lot.
Re: Hondata app datalog question ( Wideband )
Posted: Sun May 14, 2017 9:30 pm
by forevertrj
you will have to set the wide band in the closed loop advanced tab under parameters, at the top window selection row of Smanager, once you have selected the pin out (example: d14 ELD) also see THIS for wiring into pin D14 for wideband and the NOTE: about R138 and R136 if you are having voltage discrepancies with a voltmeter to what hondata is seeing.
Posted: Tue May 16, 2017 1:32 am
by ocram_88
My wideband is directory wired into analag input and not into ECU pins. Im still keeping stock o2 sensor. So i have to wire the wideband both into analog and ECU pins?
Posted: Tue May 16, 2017 1:51 am
by forevertrj
to get the input to show up in the APP as the AFR value you'll need to use the ecu pin D10 ELD pin, D12 EGR pin or B6 AN pin, leave D14 Stock Primary 02 sensor alone, if you look closely at the closed loop advanced tab, in the Parameters window, the outlined section is called Wideband Lambda, and it specifies with a drop down menu "wideband input source" I'm sure in the APP you can set view the analog inputs in the sensor list but I don't know if you can set the analog input as the AFR source in the APP, but I do know that the AFR source is dictated by the ECU pinout and the selection you choose in the closed loop advanced Tab. To answer your question, if you want to use the analog inputs for datalogging purposed fine, but to get the information into the app for the purposes you want it for it's probably easiest to run it into the D10/D12 or B6 circuit inputs. so yes you can run the wideband into D10/D12/B6 and analog input, or just D10/D12/B6.
Posted: Tue May 16, 2017 2:52 am
by ocram_88
Ok, thanks a lot! I'm gonna try and see what is going on
