S300 Base map question
Posted: Fri May 12, 2017 3:03 am
by edhem
Hey guys, just asking HOW similar are hondata base maps to factory ecu maps?
I just bought a hondata and loaded up the base map for Jdm b18c, car runs fine.
Just want to know, should I continue using the hondata base map supplied on Smanager or use factory ecu until i get the hondata tuned?
Re: S300 Base map question
Posted: Sat May 13, 2017 1:39 am
by forevertrj
you can use the hondata map, if you haven't changed your injectors, and are running NA(naturally aspirated) also run in closed loop on the stock primary O2 sensor in narrow band mode. Anything else needed for clarification?
Posted: Sat May 13, 2017 4:22 pm
by edhem
Can I do WOT with the map is what im getting at. Car is standard NA Type R just with bolt on modifications.
Posted: Sat May 13, 2017 11:32 pm
by forevertrj
if you have a wideband sensor plumbed into the exhaust you would be able to see your AFR's and you could see if you were running less then ideal numbers, at WOT on NA you should be seeing 13.5 AFR's but 12 - 13.5 is acceptable. But if your seeing 13.9-17 for AFR values that tune is no good and you'll definitely detonate.
Posted: Sun May 14, 2017 4:20 pm
by edhem
Nah I dont have any sensors, only have what the Hondata bluetooth is showing me.
Posted: Sun May 14, 2017 5:40 pm
by forevertrj
OK so your target voltage is 0.5 volts on your android app which you should be able to see in the sensor list under 02 sensor, while your in WOT make sure that you are seeing something like 0.8 or 0.9 of 1 volt as your WOT desired target voltage. the sensor will read higher voltage as air fuel mixtures get rich. Unfortunately just not accurately but you will be able to tell if your lean or rich. see this picture for a visual aid. http://4.bp.blogspot.com/-10rXkskTQRY/T ... tGraph.jpg
Posted: Thu May 18, 2017 3:54 pm
by edhem
Kept an eye on the wideband 02 reading and cruising it was 0.8, on WOT it is 0.9. Seems fine hey?
Posted: Sat May 20, 2017 2:43 pm
by forevertrj
Please see my previous post for your answer...
