Page 1 of 2
FlashProManager 2.6.7.0 & 2.6.8.0
Posted: Tue May 09, 2017 10:58 am
Changes from 2.6.7.0:
- Added language translation
- FlashPro firmware updated to version 111
- Added support for 2016 Civic Turbo including 5AN-C03 & 5AN-A93/L93
Download
here
The FlashPro now supports 30 different ECU variants for the 2016+ 1.5 turbo Civic.
FlashProManager language translation is supported, but no translation files are included with this release.
Re: FlashProManager 2.6.7.0
Posted: Tue May 09, 2017 12:35 pm
by g-gill24
Agh
Been waiting for this..but then I connect my flash pro and it's a dud. Getting a USB device descriptor fail error :( on both my computers
FlashPro bricked after 2.6.7?
Posted: Tue May 09, 2017 1:05 pm
by g-gill24
Hey,
Before this update my Hondata was working fine - was able to upload my ECU and whatnot. but after I downloaded the new one that just released. It recognized my USB/CAR and said it will update flashpro. It did the update and then my Hondata just died? When I go to device manager it says "usb device descriptor request failed". I tried multiple ports/uninstalling driver and reinstalling and even tried it on a different laptop but get the same problem.
Is my Hondata bricked? Am I screwed $800? :(
Posted: Tue May 09, 2017 1:42 pm
by typer86
Which previous version of the flash pro manager was installed on your PC?
I will wait before update until Hondata drop a comment to this issue....
Posted: Tue May 09, 2017 1:50 pm
by g-gill24
typer86 wrote: Tue May 09, 2017 1:42 pm
2.6.6.0.
The one before this.
Posted: Tue May 09, 2017 2:02 pm
First, what version of windows are you using? The instructions depend on the version because Windows 10 does things quite differently.
Posted: Tue May 09, 2017 2:08 pm
by g-gill24
Hondata wrote: Tue May 09, 2017 2:02 pm
Hey!
It was done on Windows 10
Posted: Tue May 09, 2017 3:58 pm
by g-gill24
I factory reset my laptop and it worked. But sometimes it can't detect my VIN number, I had to reconnect it 3 times to my vehicle for it to detect. Not sure if that's a bug?
Posted: Tue May 09, 2017 4:06 pm
First inspect the USB cable and the FlashPro for any problems with the USB connector.
For Windows 10 on a laptop try disabling 'Fast Startup' from the power options.
Then if it doesn't connect open up the device manager and tell us what it shows there.
Posted: Tue May 09, 2017 4:32 pm
by g-gill24
Hondata wrote: Tue May 09, 2017 4:06 pm
Hey,
I ended up factory resetting my PC and that fixed it.
Posted: Tue May 09, 2017 9:40 pm
by joecang
Hi Hondata,
When I installed this new update and uploaded my calibration to my car, it ran really bad and could barely idle. I tried to reinstall the software from your link but it keeps on downloading 2.6.6 but now my firmware has been updated to 2.6.7. I was able to get the car running properly again with the older software but now I am unable to datalog because of the newer firmware.
Any suggestions?
Thanks!
Posted: Tue May 09, 2017 9:42 pm
We're aware of the problem and working on a solution now.
Re: FlashProManager 2.6.7.0 & 2.6.8.0
Posted: Tue May 09, 2017 10:47 pm
We've made a release to fix the 8th Gen Civic problem:
V2.6.8 (9 May 2017)
• [2006 Civic Si / Type R] Fixed inconsistent injector duration.
Posted: Wed May 10, 2017 5:01 am
by joecang
Updated to 2.6.8 and working great! Thank you!
Posted: Fri May 12, 2017 1:17 am
by typer86
Today updated the firmware from 2.6.6.0 to 2.6.8.0
Issue:
The orange LED is very dark after the update! It is hard to see if the log is started or not.
It look like a little "glow" like a old LED.
Please check it.
My Flashpro is ~4 years old without BT
