7psi base map
Civic 2016+ 1.5 Turbo
coder101
7psi base map
Post by coder101 »
Hello,
New to this, anyone try the base map personally? I got a 2017 coupe ex-t and thinking of giving it a try.
malgeo
Re: 7psi base map
Post by malgeo »
I tried this yesterday. I did a quick 0-60 in roughly 7 seconds. My tires actually squealed a little bit (I don't remember exactly at which point). I'm using the +6psi calibration again just because I'm not sure if it's safe for the CVT to continue at +7psi.
http://www.mediafire.com/file/sz97to6zx8qilqp/7psi.fpdl
Jun43
Re: 7psi base map
Post by Jun43 »
malgeo wrote: Mon Aug 21, 2017 9:33 am I tried this yesterday. I did a quick 0-60 in roughly 7 seconds. My tires actually squealed a little bit (I don't remember exactly at which point). I'm using the +6psi calibration again just because I'm not sure if it's safe for the CVT to continue at +7psi.
everything looks normal. are you sure it's not the 6psi map? i dont see a +7 map. judging from the datalogs, it looks like the +6psi map
you let off a little early before hitting 60mph. Could of done it a tad faster
malgeo
Re: 7psi base map
Post by malgeo »
Jun43 wrote: Mon Aug 21, 2017 9:52 am everything looks normal
Can you clarify? Do you mean normal like it should be safe for the CVT? or normal like there's no improvement over the +6psi cal? Thanks for your insight. I'm completely new to this.
Jun43
Re: 7psi base map
Post by Jun43 »
malgeo wrote: Mon Aug 21, 2017 9:58 am
post your +7 psi calibration.
your datalog shows it running around 19psi. which is the +6psi map.
normal as in its running like it should be. It's safe
malgeo
Re: 7psi base map
Post by malgeo »
Jun43 wrote: Mon Aug 21, 2017 10:01 am
Basically I took the +6psi cal and modified the TC maximum pressure ratio from 1500rpm and up by .07 bar (1psi). Assuming this is not the correct way to increase boost to +7psi, how would I go about doing that? Thanks.
http://www.mediafire.com/file/gnvwr9btf ... 7psi.fpcal
efcee
Re: 7psi base map
Post by efcee »
any news on this?
