Hondata s300 red led flashing fast
jose_mbk
Post by jose_mbk »
My English is bad, I will use a translator. Install my honda s300 v3 in my Honda Prelude SH. Smanager does not read the engine parameters in real time. A red light flashes quickly, not before. When I connect to the PC without connecting to the vehicle also red light that blinks. What can be the motive?
jose_mbk
Re: Hondata s300 red led flashing fast
Post by jose_mbk »
The red light no longer appears but if I have the revolutions limited to 2500rpm. I have inspected the harness and it looks like it is perfect. The welds are perfect. I cut the j12. J4 I have not cut it because I read that it is not relevant. So I do not know what to do anymore.
Is this in a rectangular ECU or a square ECU?
jose_mbk
Post by jose_mbk »
37820-p28-g02 AWR
Is rectangular
Have you enabled on-board datalogging?
jose_mbk
Post by jose_mbk »
I'll check in a moment
jose_mbk
Post by jose_mbk »
Is not activated. The light only blinks when I connect the pc, I suppose that's why. My problem now is that it does not rise from 2500rpm and in idle it goes off
so you are saying the red light stops flashing when it idles?
jose_mbk
Post by jose_mbk »
The red light blinks only when the PC is connected. Now I have the problem of protection mode
jose_mbk
Post by jose_mbk »
Serial number Hondata: 39248
Serial number ECU: 37820-p28-g02
Hardware: version 3
Firmware: version 8
Software: version 2.5.5
Have you uploaded the calibration to the ECU using this version of software? Are you able to datalog?
jose_mbk
Post by jose_mbk »
I have uploaded the calibration with this version on two different PCs. I can not do datalog because it does not read the sensors. Even if it starts, it's strange
Has the s300 ever worked on this ECU?
Where are you located?
jose_mbk
Post by jose_mbk »
I dont understand that question. I live in Cadiz, Spain
