Need help please
I own a Civic type R uk 2002 EP3 with Version1 Hondata
Turbo, Built K20, PRA
Recently having a problem , as I let off the accelerator pedal, idle drops so low it can stall.
Also idles ok, but on pressing accelerator pedal at a stand still , from 1500 to 3000rpm fluctuating AFR
Fluctuating at 1500 to 3000 rpm
Re: Fluctuating at 1500 to 3000 rpm
any help would be appreciated
There's no wideband input enabled so it's hard to tell what's happening when you can't see AFR.
Also you might want to enable closed loop operation or is there any reason why you have that disabled?
I am pretty sure I checked the box:
Use an external wideband from ELD pin
Also I left it in open loop as not to have changes done by ECU
