On-board datalogging problems
Posted: Mon Apr 10, 2017 4:13 pm
Hi,
I am running the S300 v3 and am having issues with datalogging.
When I run the car connected to my laptop and recording, it runs great without any issues.
I had connected a switch to the power steering input at B8 to use the on-board datalogging function. When I test drove it like this, the car ran badly with lots of missing and wanting to die. The datalog showed sharp spikes on various sensors such as VSS, INJ, IGN. It also felt like it stumbled and would not want to rev above 4k rpm.
Initially I thought that I had wired the switch wrong, so I test drove it after disabling onboard datalogging and activating the switch to B8 just to see if somehow I was putting something weird into the ECU at B8. The car ran perfect again as if grounding B8 did not change how the car ran (which is good).
I then edited the calibration to force onboard datalogging to always be 'on'. When I did this, the car ran poorly again. Any tips on what to do to troubleshoot this? The ability to onboard log without use of a laptop is a pretty valuable feature for me. If anyone has any advice, it would be greatly appreciated. Thanks!
