FlashProManager 2.6.5
  • Added new models for the 2016-2017 International Civic Turbo:
    5AA-C65, 5AA-C55, 5AA-C67, 5AA-C57, 5AA-C07, 5AN-C14, 5AA-X54, , 5AN-G92, 5AN-G72, 5AN-G52, 5AN-G22, 5AN-E62, 5AN-E12, 5AG-P51, 5AG-Q61, 5AG-N51, 5AG-N71, 5AG-N81
  • Added FlashPro lock status to the main window status bar.
  • [09+ TSX] Added deceleration VTC control.
  • [2016-2017 Turbo Civic] Added switch for stock WOT determination.
    By default the engine will run at stoichiometric until fairly high load. This can be changed under Calibration / Closed Loop / 'Use AFM to determine WOT'. With this switched off the engine will run richer under initial load. Response will improve but fuel economy will suffer.
  • Improved connectivity to USB3 ports.
    This fixes a problem with USB connections to some USB3 ports. See Update Boot Firmware.
  • Added calibration permissions.
    This allows a calibration to be saved so that parameters & tables are not displayed and/or it can only be uploaded to one FlashPro.
Download here
Kty24
Re: FlashProManager 2.6.5
Post by Kty24 »
After using this update my flash pro won't connect to my ecu any suggestions??
typer86
Post by typer86 »
Kty24
Post by Kty24 »
Mine literally won't even recognize my ecu on or off the lap top everything just blinks.
Please follow the posting guidelines. Just saying 'it does not work' does not help us help you.
