Lambda-overlay highcam in 2.6.5 not working correctly
Posted: Thu Apr 06, 2017 12:01 am
Hi Hondata,
In latest beta 2.6.4 and 2.6.5 I have identified the following issue:
In 3 gear pull the fuel tables the lambda and lambda-overlay will only displaying in the 50 degrees table although the VTC profil (CAM and CAMCMD) displaying the real CAM angel. (The tables follow cam angle is active/enabled)
Summarize:
The fuel table will follow the VTC cam angle and switch in the correct table but the overlay (lambda values) will be displayed in the wrong table until the end....
Result:
- Hard to tune. :D (no change after adjust the values which are displayed in the overlay)
- Confusing the tuner
See screenshot below
I have this issue on two different systems:
- Surface 4 pro (Windows 10 pro)
- Standard office PC with Windows 10 pro
Thanks for help
Summarize:
Result:
Thanks for help
