Lambda-overlay highcam in 2.6.5 not working correctly
typer86
Post by typer86 »
Hi Hondata,
In latest beta 2.6.4 and 2.6.5 I have identified the following issue:
In 3 gear pull the fuel tables the lambda and lambda-overlay will only displaying in the 50 degrees table although the VTC profil (CAM and CAMCMD) displaying the real CAM angel. (The tables follow cam angle is active/enabled)
Summarize:
The fuel table will follow the VTC cam angle and switch in the correct table but the overlay (lambda values) will be displayed in the wrong table until the end....
Result:
- Hard to tune. :D (no change after adjust the values which are displayed in the overlay)
- Confusing the tuner
See screenshot below
I have this issue on two different systems:
- Surface 4 pro (Windows 10 pro)
- Standard office PC with Windows 10 pro
Thanks for help
R-12914
Re: Lambda-overlay highcam in 2.6.5 not working correctly
Post by R-12914 »
Same issue here on my Dell XPS17 Notebook with Windows 10 Pro, Version 1703!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
What vehicle & ECU is this? That will save me testing all 50 for a start.
R-12914
Post by R-12914 »
Hondata wrote:What vehicle & ECU is this? That will save me testing all 50 for a start.
In both cases, vehicle is a "FN2" and ECU part number is "37820-RSP-E03".
I hope this helps?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Are you remapping the cam angle index? What are the values? Are the indexes different between the low and high speed tables?
You could save a lot of time by following the posting guidelines.
R-12914
Post by R-12914 »
*File deleted!*
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Ok, the problem is that FlashProManager uses the low cam VTC index table for overlay, and your low and high cam indexes are different. I've changed FlashProManager for the next release.
R-12914
Post by R-12914 »
Ok, Thanks!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Thank you.
