Kprov4 not cranking randomly
JackSVM
Post by JackSVM »
Ok I edited this post. Last week I had my k20 turbo running and not it will not crank, battery is at 12v and all things inside the car work... immobiliser is NOT enabled so it's not that. This happened to me before and I reloaded the map and the car started. Is it possible the calibration can corrupt or something ?
Re: Kprov4 not cranking randomly
Cranking is not controlled by the ECU. It is the battery, starter, wiring, grounds, ignition switch and starter relay which you'd need to look at. The ETM is the place to look.
