Convert tables Fuel MAP a AFM
tiozes
Post by tiozes »
Hi,
I have an FN2 with turbo with cal RACE and I want to put AFM calibration using IAT sensor and to deactivate AFM, how do I convert the fuel tables for a correct operation?
regards
R-12914
Re: Convert tables Fuel MAP a AFM
Post by R-12914 »
You must make a fully retune!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
mladjan
Post by mladjan »
Ok, it should be retuned, but can someone post some guidance which settings in the map itself are different? What we should be aware when doing this conversion?
I also have rotrex supercharged fn2 with race calibration, and would like to create one more map which is Hybrid.
If I copy/paste tables, will car be drivable for tuning, or safe at least?
typer86
Post by typer86 »
Yes and yes. But use the vtc profile and ignition what I sent to you ;)
Lock cams 50 and Rev it at first to 5000 or 6000 RPM and watch the lambda is 0.80...
Adjust the fuel and repeat this for all other cam angles
tiozes
Post by tiozes »
To work the AFM sensor has to be installed? Or can I remove it and have only the MAP sensor?
You can disable it, there really is no need to completely remove it. IT contains the IAT sensor so if you do remove it, you must wire in a proper IAT sensor as well.
typer86
Post by typer86 »
Spunkster wrote: Fri Aug 18, 2017 9:29 am You can disable it, there really is no need to completely remove it. IT contains the AIT sensor so if you do remove it, you must wire in a proper IAT sensor as well.
Yes IAT relocation is recommended...
