P1607 ecu internal circuit malfunction and ecu going offline????
Posted: Wed Mar 29, 2017 10:59 am
by Adamk20aek9
Right I have a civic ek9 with k20a fitted, kpro v4 with latest software. Tuned by a company here in the U.K.
Bringing up error code p1607 and when tuning the car the ecu keeps going offline.
Checked selected calibration and they have selected a PRB ecu when it is a PRA what is fitted.
Should this be changed when the car is next tuned?
What can be causing the ecu to go offline? Ngk Resistor spark plugs are used.
The setup is 3" exhaust, race header and jenvey itbs.
Any help would be greatly appreciated.
Re: P1607 ecu internal circuit malfunction and ecu going offline????
Posted: Wed Mar 29, 2017 1:24 pm
You can only use a PRA calibration on a PRA ECU or you will get that error.
Posted: Thu Mar 30, 2017 1:04 am
by Adamk20aek9
Having the wrong ecu selected is that a bad thing apart from putting an error code up? Will it effect how the car runs?
What could be the cause of the ecu going offline when trying to tune the car?
Thanks for the reply/help.
Posted: Thu Mar 30, 2017 9:31 am
Are you using resistor or non-resistor type spark plugs?
You should not use a PRB calibration on a PRA. Running with the error code is not a good idea.
Posted: Fri Mar 31, 2017 12:46 am
by Adamk20aek9
We are using ngk resistor spark plugs. What else could be causing the ecu to go offline, it only does it when the car is being tuned.
Ok we will start a new calibration with it. Ring the incorrect ecu selected.
Posted: Fri Mar 31, 2017 9:23 am
Are you using the USB cable provided by Hondata?
Posted: Fri Mar 31, 2017 12:26 pm
by Adamk20aek9
Yes it's the cable which came with the ecu new last year.
Posted: Fri Mar 31, 2017 1:26 pm
HAs anything been done to the ignition system on the vehicle?
Has the engine bay ground been relocated properly?
Posted: Sun Apr 09, 2017 7:59 am
by Adamk20aek9
Hi
Still having issues with the kpro going offline when tuning the car.
Engine ground got moved again and still the same issue.
Anything else to try or is it best to send the ecu off to be checked?
Thanks.
Posted: Tue Apr 11, 2017 3:57 pm
I would recommend that you try the ECU in a different vehicle to see if the problem follows the ECU or is specific to the vehicle.
