Kpro4 with aim evo4 and mxs dash and sensor questions
Posted: Wed Mar 22, 2017 8:26 am
I'm trying to find the info but maybe I've been web challenged and can't find on either aim or hondata site.
Honda S2000, with krpo4.
Can I use the can out to drive the dash and the rs232 to send info to the evo4 simultaneously.
I've been using an mxl dash driven directly from the evo4 but there might be some connectivity issue and it might be easiest for me to use the can to drive dash and rs232 to data logger (rs232 logs more of what I want).
Other question. The auto meter fuel pressure gauge, maybe I've read conflicting info, does it require a resistor or change of configuration if out to the analog in? Also, I'd like to put oil temp and pressure to the kpro, are those sender working directly or do I need to do the resister route?
Thanks for the help on these
Aaron
Aaron
