Page 1 of 2
B16Turbo... Smanager not active Upload, Dataloging buttons
Posted: Fri Mar 10, 2017 10:53 pm
by lehabaev
Hi all, i have b16a1 and P29 + Hondata S300.
Previously, everything worked well. But now driver installed, connection online but buttons Upload and Datalog is not active.
Please see screen shot.
Need help...
Re: B16Turbo... Smanager not active Upload, Dataloging buttons
Posted: Mon Mar 13, 2017 9:17 am
Posted: Mon Mar 13, 2017 12:12 pm
Is the vehicle ignition on?
Posted: Tue Mar 14, 2017 9:08 am
by lehabaev
Yes, ignition on.
This serial number?
Posted: Tue Mar 14, 2017 9:44 am
Posted: Tue Mar 14, 2017 9:47 am
by lehabaev
Software was updated around 1 a week ago.
Version 2.5.5.0
Posted: Tue Mar 14, 2017 10:25 am
The S300 is not seeing that the ECU is powered on. Check the S300 is seated correctly in the ECU, then start checking the main relay and fuses.
Posted: Tue Mar 14, 2017 10:29 am
by lehabaev
Can i check work state on the S300 (green light, red light etc..) ?
Posted: Tue Mar 14, 2017 10:40 am
Also check to make sure that there is nothing leaking from any of the capacitors on the ECU. There is a very high possibility that the capacitors are going bad and need to be replaced.
We offer a replacement kit for this:
https://www.hondata.com/products/access ... acitor-kit
Posted: Tue Mar 14, 2017 10:49 am
by lehabaev
Spunkster wrote:Also check to make sure that there is nothing leaking from any of the capacitors on the ECU. There is a very high possibility that the capacitors are going bad and need to be replaced.
Leaked capacitors looks like that?
Posted: Tue Mar 14, 2017 12:00 pm
They are over 20 years old, I would highly recommend that you replace them just to be safe.
Posted: Wed Mar 15, 2017 5:17 am
by lehabaev
I replaced C21 and C24 capacitors, but nothing changed.
When i connect PC to S300 (without ignition) SManager show online status.
When i turn on ignition, nothing not change.
Do you have any other ideas?
Posted: Wed Mar 15, 2017 8:42 am
by lehabaev
I recorded video with my problem. When you listen beep-beep it's i turn on ignition..
https://youtu.be/dbVI-czqScs
Posted: Wed Mar 15, 2017 8:59 am
It is not getting power through the ECU.
Posted: Tue Mar 28, 2017 4:46 am
by lehabaev
Hondata wrote: not getting power through the ECU.
Which S300 pin getting power? How i can check this?
Please see this image(with lamps); How should the lamps light up?
