Hello,
i need help, please need base map for block b18a whit pistons p30, head Pr4 Non-Vtec, Intake k n, hondata S300 V3.
MLS Cometic gasket.
thanks,
B18A whit p30 pistons
Zperformance
Re: B18A whit p30 pistons
Have a wideband install and adjust afr to spec. Timing is retarded a bit to compensated for the higher compression. Let me know how it do and if there is any problem.
Thanks recent install brian cower bc0022 and bc0020 change the base map?Zperformance wrote:Have a wideband install and adjust afr to spec. Timing is retarded a bit to compensated for the higher compression. Let me know how it do and if there is any problem.
Zperformance
timing is a bit conservitive just add fuel and should be a okay basemap.
