Car wont idle correctly while moving
Posted: Sat Feb 11, 2017 3:09 pm
by chrisbogart
s300v2
b18c turbo
1000cc ID
IACV duty cycle in the middle @ normal
In the IDLE parameters i have my moving minimum idle set to 1500rpm but it does not work.
also if i adjust idle while stationary and upload nothing happens.
ive attached datalog recording
update: attached calibration
Re: Car wont idle correctly while moving
Posted: Mon Feb 13, 2017 10:41 am
You have not posted the calibration that the datalog was made with.
Posted: Wed Feb 15, 2017 10:53 pm
by chrisbogart
uploaded calibration
also, you can see in the datalog that when i let off throttle to coast, my fuel duty cycle goes to 0% and almost dies.
Posted: Thu Feb 16, 2017 11:18 am
I don't actually see a problem in that datalog. The fuel injectors are supposed to shut off during deceleration, so that is normal. Have you set the idle per the factory service manual instructions?
Posted: Thu Feb 16, 2017 10:30 pm
by chrisbogart
my idle adjustment screw is almost closed.
i dont understand why the minum moving idle drops below where its supposed to and never corrects
i didnt decel in gear, i simply put the clutch in then the rpms drop too low and duty cyle goes to 0% from 6.8 seconds on datalog to 7.3
Posted: Fri Feb 17, 2017 10:47 am
With the car fully warmed up and idling, unplug the idle control connector and see what RPM it idles at.
Posted: Tue Feb 21, 2017 5:31 pm
by chrisbogart
what will this determine? if my IACV is working or not?
To see if it is adjusted properly.
Posted: Sun Apr 23, 2017 5:31 am
by chrisbogart
So idle is adjusted properly. but the s300 still wont change idle and doesnt catch a falling idle when pushing clutch in.
Posted: Mon Apr 24, 2017 9:23 am
with the IACV disconnected, what does it idle at?
Posted: Sat May 13, 2017 2:01 am
by forevertrj
chrisbogart, please tell us the idle RPM while the IACV plug is disconnected, don't answer with the idle is set right, if the screw is almost fully closed I guarantee it isn't set right. Please view http://www.hondata.com/help/smanager/se ... espeed.htm to better understand the reason for our question about he RPM value.
Posted: Sat May 13, 2017 2:03 am
by forevertrj
if the idle isn't correct when adjusting the set screw, while the IACV is disconnected, there is a high probability of a vacuum leak.
