** Cant upload anymore - Vin does not match **
Posted: Thu Jan 26, 2017 10:23 am
Flashpro error message: (Vin does not match) when trying to upload. Flashpro is still locked to the car and suddenly stopped to program.
I can't upload any cals to the ecu either by using the laptop or the program button on the flashpro itself. It suddenly happened for no reasons apparently. Software is up to date (2.5.9) and so drivers and i even tried a different cal to make sure it was not a bug with the cal itself. I bought the flashpro new at the end of summer 2016 and since then i never unlocked it from ecu nor have problems, this is the first time this is hapenning to me. On Flashpro manager if i click on flashpro i see the Hardware Firmware and license is green but the upload section is yellow which indicate a problem: Last upload failed. However i can still datalog with the engine on. I need to load a new map to my car but i can't...
Your name: Sebastien Potvin
Your location (country, state and city): Canada, Quebec, St-Bruno
Car model and year: 2012 honda civic Si
Engine type. 2.4L naturally aspirated
ECU number: 37820-rx0-a03
Flashpro serial: FP-2012Si-112923
Car Serial: 2HGFG4A57CH101657
Any relevant modifications (engine - not suspension!): Car is stock except Cold air intake
I've sent the information to hondata with the obdII plugged / Key on
Please help.
Thank you
Please help.
Thank you
