new to Hondata and having issues
Posted: Tue Jan 10, 2017 7:44 pm
by cityofcaterpillars
I have an s200 v1 in a po6 with vtec conversion. Engine is a stock d16z6. Innovate lc-2 wired to d10
I'm having a few issues with it. When I tune the map the AFR keep changing. I can get it to idle at 14.7 but after a drive at idle the AFR will be as low as 10:1 or as high as 16:1 according to the wideband gauge. when datalogging its not recording the same AFR's. Yes I adjusted the voltage offset.
The ecu will periodically lose connection with the laptop and the reconnect. Data logging will freeze. And last but not least it keeps recording a code 9 CYP error. I know this is false because I have used different ecu's and there's no CEL.
Any help with be great.
Re: new to Hondata and having issues
Posted: Tue Jan 10, 2017 9:09 pm
Serial number is s300 8672
Posted: Wed Jan 11, 2017 12:18 pm
Are you using resistor type, or non-resistor type spark plugs? If you do not get an error code with a different ECU then it sounds like your ECU is damaged and will need to be replaced.
Posted: Wed Jan 11, 2017 1:57 pm
Im not sure on the spark plugs Im going to check that today. Is there a difference between spark plugs with resistors and plugs that say resistor type : suppressor. Would the wrong spark plugs cause the other problems besides the freezing?
Posted: Wed Jan 11, 2017 3:25 pm
Checked the plugs and they do have a register. They're NGK
Posted: Wed Jan 11, 2017 4:13 pm
Since you have emailed us about this there is no need to continue posting in the forum.
