new to Hondata and having issues
cityofcaterpillars
Post by cityofcaterpillars »
I have an s200 v1 in a po6 with vtec conversion. Engine is a stock d16z6. Innovate lc-2 wired to d10
I'm having a few issues with it. When I tune the map the AFR keep changing. I can get it to idle at 14.7 but after a drive at idle the AFR will be as low as 10:1 or as high as 16:1 according to the wideband gauge. when datalogging its not recording the same AFR's. Yes I adjusted the voltage offset.
The ecu will periodically lose connection with the laptop and the reconnect. Data logging will freeze. And last but not least it keeps recording a code 9 CYP error. I know this is false because I have used different ecu's and there's no CEL.
Any help with be great.
cityofcaterpillars
Re: new to Hondata and having issues
Serial number is s300 8672
Are you using resistor type, or non-resistor type spark plugs? If you do not get an error code with a different ECU then it sounds like your ECU is damaged and will need to be replaced.
cityofcaterpillars
Im not sure on the spark plugs Im going to check that today. Is there a difference between spark plugs with resistors and plugs that say resistor type : suppressor. Would the wrong spark plugs cause the other problems besides the freezing?
cityofcaterpillars
Checked the plugs and they do have a register. They're NGK
Since you have emailed us about this there is no need to continue posting in the forum.
