PRA wideband Install?
Posted: Fri Jan 06, 2017 9:21 am
by JackSVM
Hi I'm new to this forum, Iv nearly finished my boosted k20 ep3.
I'm wondering can I use my AEM wideband lambda and wire it into the ecu ?
The car will be used/modified/raced/data logged regularly so I need to know my af's are sweet.
Jack
Re: PRA wideband Install?
by JackSVM
Iv got Kpro on my PRA ecu btw.
Posted: Fri Jan 06, 2017 9:28 am
What KPro do you have?
Posted: Fri Jan 06, 2017 12:48 pm
by JackSVM
Kpro4
Posted: Fri Jan 06, 2017 1:10 pm
Posted: Fri Jan 06, 2017 1:38 pm
by JackSVM
Sweet !
That's exactly what I was hoping for.
I can also wire my other AEM sensors in This way aswell then can't I? (Oil pressure/temp and water temp)
Posted: Mon Jan 09, 2017 10:19 am
correct
Posted: Fri Jan 20, 2017 9:57 am
by aaron johnson
Ok. So I'm new to the kpro and in fact to computerised cars.
I've got an s2000 which I've fit a kpro4 to which I'm running in scca e production.
I have an aim evo4 data logger hooked up to the digital inputs using the can wires. I'm looking to switch from the stock o2 sensors to a plx dm-6 wide band o2 to run in closed loop configuration. Which wires in the digits input do I use to wire the plx to on the kpro to do this.
Aaron
Posted: Fri Jan 20, 2017 10:16 am
Have you read the links above?
Posted: Fri Jan 20, 2017 10:46 am
by aaron johnson
If I'm reading correctly I would wire to the purple serial wire.
Do you have suggestions for grounding? Should everything should be grounded to the same point?
Posted: Fri Jan 20, 2017 11:13 am
Correct, you will probably not need to us any ground for the signal. Just the switched power and ground for the controller to work.
