Hey Hondata,
Would you mind reviewing this base map for engine Run in? Currently 6 psi boost cut, vtec disabled, low speed maps only tuned. Would you mind specifically checking the low speed ignition timing tables to see if these are reasonable for a run in tune. There was no detonation on the tune - however just want to make sure these are as minimal as possible in the run in period.
B18C GSR Turbo - 9.0:1 CR - Pump Fuel
- OEM sleeves
- JE Pistons
- Eagle Rods
- ID 1000cc Injectors @ 3 Bar base pressure
- Oem head
- Turbonetics T3/T04B .64AR 57 Trim
- 2.5" Exhaust
B18C GSR Turbo - Base map Review
Lyle_57IAL
Zperformance
Re: B18C GSR Turbo - Base map Review
Seems okay for a break in basemap.
