P0498, p2647 and p0453 - Brazillian FA5
FlavioSantos
Post by FlavioSantos »
Hello,
I have a '11 FA5 that uses a RRD-M220 ECU. When I upload a AFM calibration the ECU enters in limp mode with P0498, p2647 and p0453 DTCs.
Is possible to bypass the P0498 DTC, but the car remains in limp mode. There is a way to add the other 2 bypasses in misc/vTEC options? (as in 2012-2015 Si calibrations)
Thanks.
FlavioSantos
Re: P0498, p2647 and p0453 - Brazillian FA5
Just to add some info: When using race calibrations the ECU works as intended.
FlavioSantos
@Hondata
May you help please?
Your only option since it is using US ECU code is to use the race calibrations.
FlavioSantos
This is a issue with my flashpro unit or the ECU?
IT is a difference between the ECU circuitry, the vehicle hardware and the code inside the ECU.
FlavioSantos
Is there something I can do to make it work with hybrid calibrations? I really want to use the full throttle shift feature..
Thanks.
I'm sorry, but there is no other way.
FlavioSantos
Kinda disappointing.
