I'm looking for a car to play around with, with a boosting system that I developed.
A Honda with S300 system seems perfect for that because of the MAP sensor, price and possibilities.
I like to have the following specs:
- Cheap car because probably it will brake down (located in Europe, preferably the Netherlands).
- Base map calibration
- 2.0 liter or bigger
- max boost 0.4bar / 6psi
Correct me if i'm wrong, seems that the Europeaan Prelude or Accord 2.0 will not work with the S300 system.
Whereas I'm not a Honda expert, it's hard to find the right car, engine, map combination.
I have a background in electrical engineering and not afraid of soldering etc. but I prefer plug&play.
Hopefully someone can give some tips!
Buy simple S300 setup
Re: Buy simple S300 setup
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s300 ( https://www.hondata.com/index.php?_route_=s300 ).
danielhilgersom
Thanks Spunkster for the reply.
So the second link mentions all Prelude's from 1992 till 2000.
But there is no Prelude in the first link with ECU's.
Can I expect that the S300 setup will work with any Prelude or only a couple of editions/engine's.
It will work with all those years manual Preludes. You must use a compatible OBD1 ECU with the s300.
danielhilgersom
If I understood correctly, the 2.0liter Prelude/Accord engines are not compatible?
You should be able to use it on them as long as they have an OBD1 distributor and use a compatible OBD1 ECU.
danielhilgersom
Okee thanks,
Now I understood that it can be every car as long as you swap the ECU with one on the list.
