cant upload map
windspot
cant upload map
Post by windspot »
hello. after installing the latest software for kmanager i cant upload anymore maps it just telling me that upload is failed...
i tried to downgrade back to the older version but now it sais that is out of date and i cant use it anymore... please help... version is 4.3.1 thanks
Re: cant upload map
Don't downgrade software versions.
Perform Online -> Tools -> Erase ECU. Then power off the ECU and unplug the USB for 2 minutes. Then connect and try to upload.
Also check the battery voltage is ok.
windspot
Re: cant upload map
Post by windspot »
i cant even erase cpu it says the same that erase failed...
the battery is brand new so..
Mr. Bobby
Re: cant upload map
Post by Mr. Bobby »
I'm having the same problem. It's very frustrating.
Re: cant upload map
What is the serial number that is on the K-Pro Board inside the ECU?
windspot
Re: cant upload map
Post by windspot »
can i see it from the info or i have to open the cover of the ecu?
Re: cant upload map
Open the lid and look at the board itself.
k24_chris
Re: cant upload map
Post by k24_chris »
hey I'm having the same problem with my kpro 4. I purchased it oct 31 2016 from phearable.net
ecu# 37820-pnf-a12
kpro 4# 44406
software#4.3.2.0
I cant upload my map. (upload failed)
I cant erase ecu (security failed)
Re: cant upload map
Did it ever work?
k24_chris
Re: cant upload map
Post by k24_chris »
The weekend that just passed was the first time I actually messed with the kpro due to fuel system wasn't finished... wat had me confused, I had the kpro connected to the laptop only and it said driver installed, ignition on, and online on. And once I tap the lightning symbol it says data log. Is it supposed to do that without it be connected to the car
Re: cant upload map
Are you saying that it says online, and ignition on with only the USB connected and not being plugged into the vehicle harness?
k24_chris
Re: cant upload map
Post by k24_chris »
Yes
Re: cant upload map
Close the program reopen it. You must have it plugged into the vehicle with the key in the on position for you to be able to upload.
k24_chris
Re: cant upload map
Post by k24_chris »
Hey spunkster. I tried the kpro in a friends car and it does the samething. Can I just send it back to hondata to get it checked out?
Re: cant upload map
Send an email to support <at> Hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
