09 TSX fan control not working
Posted: Wed Nov 09, 2016 7:55 am
I used a base map from hondata to flash into this 2009 tsx AT.
The fan control does not work according to what i set, its works only from 94 degree and stops at 87 degree.
i set it to 90 degree and even disable the second ECT sensor but still does not work.
The other issue is the throttle map as shown is a base given by Hondata, after flashing in the car was slow like a tortise.
I checked the datalog and saw that when request for 15% throttle pedal the throttle plate only opens 4 or 5 %.
What could be wrong, most of this base maps work well, is there a problem to the throttle map?
