Hello,
When enabling knock sensor flashing MIL, will this disable the other uses of MIL ( For example engine light for o2 sensor problem for example or lean protection light).
Because i had an engine cut out and when i datalog i found really lean afr at high revs which must enabled the lean protection but no MIL light came on.
Kpro v2
K20a with i/h/e
Thanks in advance,
Constantinos
MIL Light
Re: MIL Light
Enabling knock sensor flashing MIL does not disable the normal MIL behavior.
As far as I know the MIL does not come on because of lean conditions, I haven't seen an option to enable this either.
