Idle Floating When Clutching
terrorista
Post by terrorista »
Guys,
After some changes on Throttle parameter I'm facing some Idle floating.
Do you have some advice on how to work to reduce TP lag and keep it stable?
Here the calibration:
Setup:
Tyres: 225/50/17
TurboCharger - K24 - T04 -> Custom Intake
Fuel: E 100%
Injectors: Bosch 160lbs
Exhaust - Custom Made
Thanks by your help.
Re: Idle Floating When Clutching
Have you tried going back to the settings you were using previously to see if it idles properly with them?
terrorista
Actually not yet ...
I was wondering how the throttle process table works. BTW Ill do that and reset the values.
Thanks,
