Laptop won't connect windows 10
LORDWD40
Post by LORDWD40 »
Hello. First post please so be kind ;)
I've got Hondata s300 v3 fitted and traction control. Cars been set up by my tuner and drives spot on. I just want to use my own laptop and connect to the ecu so I can change things like launch control and set up the Bluetooth ect.
I've got windows 10 and download the latest smanager. Plug into the ecu through the traction control (as I was told I could) and the smanager says in the bottom left corner " drivers not installed correctly" it disappears and in the corner says drivers installed and say offline next to it.
Don't know what to do now. Had a scroll around the net and can't seem to find any answers. Can anyone shed some light on this and help
Thanks in advance
Re: Laptop won't connect windows 10
You need to connect the USB to the s300 itself in order to make any changes.
LORDWD40
Post by LORDWD40 »
Spunkster wrote:You need to connect the USB to the s300 itself in order to make any changes.
What's the port on the traction control for ?
Datalogging traction control data and changing traction control calibration settings.
LORDWD40
Post by LORDWD40 »
Spunkster wrote:Datalogging traction control data and changing traction control calibration settings.
So shouldn't the laptop connect and find something. To at least get thet information ?
You need to have the s300 plugged in via USB to make any changes to it or datalog from it.
