Fuel pressure sensor wiring Innovatel motorsport
RofromNorCal
Post by RofromNorCal »
Hello I was wondering if anyone knew what wire to use to data log
On the
0-100 PSI Sensor - #RTD-WB-762 from
Innovative Motorsport
Link is on the bottom
I know the red wire is switch 12
Black is to ground, but they ask you to use a control module for it.
I was wondering if anyone on here have use this fuel pressure sensor just by it self.
And how did you wire it up for the datalog input signal?
http://www.innovatemotorsports.com/xcar ... 265&page=1
Re: Fuel pressure sensor wiring Innovatel motorsport
If they say you need a control module for it, then you probably need that. You should contact Innovative about this as they should be able to give you the correct info.
RofromNorCal
Spunkster wrote:If they say you need a control module for it, then you probably need that. You should contact Innovative about this as they should be able to give you the correct info.
I will thank you for your feed back!
What fuel sensor do you recommend.
The AutoMeter?..
Any other brands
They all seem the same part underneath. I'd use the Autometer.
jaygeezemail
Post by jaygeezemail »
I was wanting to put a fuel pressure sensor in my car. Can the s300 v3 do this?
94 4dr. gsr 201,000 and growing miles running 10lbs from a cx racing turbo.
Hondata s300 v3 p28, cpr, rc440cc, pro series IM, 70mm tb, lc2 wb, half core rad. Cx turbo and other things
jaygeezemail
Nevermind. I answered my own question.
