P006 on s2000 new install
Posted: Sun Oct 16, 2016 2:22 pm
by Pcc5001
I recently installed the k pro conversion in my ap1 s2000. I am getting an intermittent p006 code that says the primary oxygen sensor is slow to respond. It's averaging about 6 starts after I reset the code that it comes back. Could this be anything aside from the primary oxygen sensor? It seems strange that the oem computer never said there was anything wrong with it but now with the k pro it is not working properly.
Re: P006 on s2000 new install
Posted: Mon Oct 17, 2016 9:56 am
Are you sure that is the error code? There should be one more digit.
Posted: Tue Oct 18, 2016 10:05 am
by Pcc5001
I was just going off of memory on the actual trouble code. Apparently I forgot the code it's throwing. As soon as it pops up again I'll post back. I know it was saying the primary oxygen sensor was slow to respond.
Posted: Tue Oct 18, 2016 11:11 am
by Pcc5001
P0133 is the code. Bank 1 sensor 1 slow to respond
Posted: Tue Oct 18, 2016 11:23 am
Please post the calibration you are using.
Posted: Tue Oct 18, 2016 4:22 pm
by Pcc5001
The Calibration is "PRA- Euro Civic Type R/ s2000"
Posted: Tue Oct 18, 2016 4:56 pm
please post the actual calibration you have uploaded to the ECU.
Posted: Tue Oct 18, 2016 6:22 pm
by Pcc5001
here it is
Posted: Wed Oct 19, 2016 9:27 am
It sounds like you have a failing o2 sensor. I would recommend that you try replacing it.
